Testing Phono Cartridges
Page 2 of 2 Previous  1, 2
Re: Testing Phono Cartridges
Post by Bill Cahill on Wed Apr 27, 2011 8:51 am
Without knowing more about the phonograph, I can't say.
Ceramic cartridges are faily low voltage.
Magnetic cartridges are electromagnetic, and, have to have an extra pre-amp stage in order to work properly.
If it's a childs' rp, I guarantee it doesn't use a magnetic cartridge.
Number of posts: 859
http://billcahill.webs.com/
Post by John Maxson on Thu Apr 28, 2011 10:44 am
The 1947 Silvertone does humm when the positive lead is touched. When I touch the negative lead, the humm reduces. When I rub my finger across the positive lead, I get the scratch sound through the speaker. So, I would assume that my cartridge is bad. I put a meter to it on the 1K scale and it went up a little. I didn't get a reading off of it.
John Maxson
Number of posts: 43
Registration date: 2011-03-19
Post by Bill Cahill on Thu Apr 28, 2011 7:24 pm
Meters cannot read cartridges, but, I guarantee the cartridge is bad.
You need a crystal cartridge, or, higher voltage ceramic.
How manny tubes in this set?
Post by John Maxson on Fri Apr 29, 2011 9:47 am
Without looking again I think it has 5 tubes. How much would it cost to rebuild the cartridge? Is it better to put a ceramic one in?
John Maxson
Number of posts: 43
Post by Bill Cahill on Fri Apr 29, 2011 2:23 pm
That would depend on the cartridge. Personally, I think it's better to get original re built.
There is a companny in Ohio that still does it.
Not sure of cost. Maybe 40.00 with needle, but, don't hold me to that.
Post by John Maxson on Mon May 02, 2011 10:50 am
I found a site that explains rebuilding by replacing the crystal with a piezo element from radio shack. The element is only $2.00, and will pick one up and try it out.
John Maxson
Number of posts: 43
Post by bill57 on Mon May 02, 2011 7:09 pm
That sounds interesting, John. So what is the site? Let us know if you try it. I would like to try rebuilding one also if I could find a way to replace the crystal. I have about 8 players now that have bad cartridges so if you find a more economical way to do it that would be great.
bill57
Senior Member
Senior Member
Number of posts: 81
Registration date: 2009-01-21
Post by John Maxson on Tue May 03, 2011 8:36 am
I will post the site tomorrow when I can get at teh printout. I brought 2 piezos and took one apart. It looks like an easy fix.
John Maxson
Number of posts: 43
Post by John Maxson on Thu May 05, 2011 7:54 am
http://www.angelfire.com/electronic2/radiosean/tv/Cartridge-rebuild.htm
John Maxson
Number of posts: 43
Post by bill57 on Thu May 05, 2011 9:28 pm
Thanks for posting the web site. I will pickup one of these and try it.
bill57
Senior Member
Senior Member
Number of posts: 81
Post by John Maxson on Fri May 06, 2011 8:16 am
I made mine a little bit bigger to eliminate resoldering. I will pot out the back end with silicone and solder the existing wires to the phono wires with heat shrink over the joints instead of using the bus pad. I assembled it last night and I will try it out tonight.
John Maxson
Number of posts: 43
Post by John Maxson on Thu May 19, 2011 8:12 am
I tried to crimp the crystal holder down and I broke off one of the arms. I tried hot gluing the piezo to the arm. It held but the sound was very faint. The holder is aluminum so it does not take solder. I don't know what the function of size of the piezo would be to the amount of sound that It will generate.
If I can find a cartridge from a child's phonograph, that would be crystal?
John Maxson
Number of posts: 43
