Testing Phono Cartridges
Page 1 of 2 • Share •
Page 1 of 2 • 1, 2
I have a 1947 Silvertone radio/ player. The radio works great but the phono does not put out any sound. I brought a 78/lp cartridge on ebay and hooked it up to an RCA jack and plugged it into the chassis in place of the original line. I get no sound. I also tried plugging that Jack into a modern portable boom box that has an aux jack and got no sound. How can I test the cartridges to get to the source of the problems? I would like to test teh new one and the old 78 one.
John Maxson- Member
- Number of posts: 43
Registration date: 2011-03-19
Re: Testing Phono Cartridges
They probably used a crystal cartridge, over time they no longer function (Just like crystal earphones). I doubt they are magnetic cartridges-too old for that. May just have to install a newer turntable and use a preamp to work. $$$$
Resistance is Futile- Admin
- Number of posts: 627
Still need to test the new one I got. It is NOS. Can I replace the crystal one with a modern one?
John Maxson- Member
Newer turntable!?
Are you kidding?
How about putting in a decent ceramic cartridge with the correct voltage?
Not all crystal cartridges go bad.
The reason they most often go bad is extreme termperature changes. They especially don't like high temps.
What is the RCA number on cartridge? If it's an old crystal, it may very well be bad, also.
The old cartridge not working is usually because the cartridge has gone bad.
As I said, they hate extreme temperature changes. ESPECIALLY heat.
I have some 15 yr. old rebuilt cartridges that are still good.
I also have some older crystal cartridges, including two made in the 70's, that are still very much alive. Why?
Because they weren't subjected to high heat.
Attics, garages, sheds, etc., are good examples of bad storage places.
Are you kidding?
There are cartridge rebuilders, by the way.
Not cheap, but, I've had sme rebuilt with great results.
Welcome to the forums....
I found some info on a website. They say that if you touch the cartridge leads together the unit hould make a loud buzz with the volume all of the way up. I tried that and I don't get any buzzing. The radsio does work. Is there a certain tube or circuit component that would be disfunctional even with good radio operation? (1947 Silvertone AM/phono)
John Maxson- Member
Ahh.Now were getting somewhere. Check the phono leads from the cartridge with an ohmmeter. you should get continuity in both leads. If not check to make sure one of the wires isn't broken. check the phono connection(s).
It could be that the phono radio switch needs cleaning or it may be broken. Trace the wire back through the switch, and use caution while touching only the phono connections. This is called tracing the signal. If the radio works then it is definitely a bad connection to the phono. Correct the wire default(s) and you may be surprised that the cartridge still functions.
F9rst of all, the information given is incorrect. If you touch the red lead with your finger, with cartridge disconnected, you should get a buzz.
If you do, then, put another finger strongly on the black, or, ground lead at the same time. If the volume of your buzz goes down, that is not your problem.
It is, as stated earlier, your cartridge.
Bill, You been in the 807's again ? ..... Gregg
kb4yrc- Member
- Number of posts: 21
Registration date: 2008-05-20
No I think Bill is referring to the incorrect statement about shorting the phono wires together, that part is incorrect information on the posters interpretation of what he understood he should do.
Bill is correct in stating that just touching the wire while the leads are connected to the radio in the phono position are right. The concept is to introduce hum into the red lead whilst the cartridge itself is disconnected but the wires that go to the phono amp are used. Using your fingers on both the red wire and the return wire at the same time on the second test would indicated if the hum is reduced the second wire is correctly connected to ground, therefore a reduction in the hum should be noticed as the fingers are in part now, acting as an attenuation, redirecting the signal to ground..and showing that wire isn't open.
807's????
I'm simply saying touch the red, or, insulated wire with your finger. You should hear a hum.
To check wiring, touch both wires at once. Yolu should hear a decrease in volume of the hum..... Correct.. That is exactly what I was saying. Thank you......
I will check the connections. One thing I notice is that The printing on the knob is opposite of the direction to turn the knob for each selection.
John Maxson- Member
I was refuring to Bill's typing skills. ..... Gregg
kb4yrc- Member
My typing skills are good. I was very tired.
What is the difference between ceramic and magnetic cartridges? Which does a late 60's phono take?
John Maxson- Member
Page 1 of 2 • 1, 2
Page 1 of 2
