My Magnavox 1946 model RC-198C radio-phonograph
I feel like I have hijacked Ron's thread, so, I have my own, now. I wish to show the progress of restoration on my Magnavox. I will show beginning, to where it sits on the bench now. It's nearly ready to go back together, and, try. I had replaced the paper caps in it sme years ago, and, just replaced the electrolytics. I did a complete cleanning of chassis, and, re painted top of power transformer, which was rusty.
Tell me what you think, guys......
Billl Cahill
Billl Cahill
Re: My Magnavox 1946 model RC-198C radio-phonograph
....And, here are the after pictures.......
I put radio together last night with the intention of trying it. While checking controls, I found tunning mechanism wasn't moving. I stopped there. After sleeping a little, I figured it out. I forgot that this system has a wonderful mechanical tunning, including the push buttons. The problem it it has gummed up. That's very repairable, but, in order to do this, It must be taken back apart, and, I must remove the top shield panel to get to the mechanism.
Oh, well.
Oh, well.
Do you have the record changer for it?
Tony V- Senior Member
- Number of posts: 102
Registration date: 2008-09-13
I have a correct WC model 56 made for Magnavox for it.
Way ta go Bill! Nice work.
Looks like a set that should have decent sound too.
ve1arn- Member
- Number of posts: 34
Thanks very much. Last night, I did the job. I took it apart, and, put it on the bench. I took front panel off, and, removed the shield. With alot of work I got it working mostly well. Occasionally, one of the buttons will stick some, but, mostly not, and, tunning spins like a top....
It has a 3 ganged tuner, so, it has tuned RF. This is actually a good radio. Apparently, one of the higher end lower wattage sets......
Set uses 10 tubes.
1 5U4 rect.
2 6L6 audio Output.
1 6SN7 inverter, and, pre amp.
1 6SJ7 pre amp.
1 6SA7 Oscilator.
1 6??? RF.
2 6SK7 I F tubes.
1 6U5 Eye Tube.
Sorry I forgot number of RF.
Anyway, it's a nice set.
Hope to try it today. Still have to put it back together.....
Wish me good luck.....
Set uses 10 tubes.
1 5U4 rect.
2 6L6 audio Output.
1 6SJ7 pre amp.
1 6SA7 Oscilator.
1 6??? RF.
2 6SK7 I F tubes.
1 6U5 Eye Tube.
Great news!!!!
Tonight, I tried the radio, and, it plays... There are some bugs to overcome, but, it's playing!
I can't seem to get the adjustments for push buttons to work. I loossen the screw, tune it, etc., then, tighten it, but, it goes back to its' old setting...
Hmmmmm....
What could I be doing wrong????
Has nice fidelity. It acts like it either needs minor alignment, or, has a bad tube.
Eye is very bright, but, is barely moving at all.....
One dial light isn't working. Power transformer is great. After 40 min. of playing, it's still cool as a cucumber.
But, boy, do those power tubes smell hot!!
This set has excellent bass, and, good treble. Gets many stations. SW also works.
This baby is ALIVE!
Hmmmmm....
This baby is ALIVE!
Similar topics» BBC Radio Play - The Castafiore Emerald
» EQSO PMR Radio Programme Download
» (GAMBAR) Feeya DJ Radio ERA Kantoi Baju Koyak
» Model prezentare !
» [MODEL] Cerere Rank
